cindersailor
I would be grateful for the experience of anyone who has painted topsides using International perfection (2-pot polyuethane). I have heard various horror stories about using this paint so I thought I would try to gather as much information as possible before I open the tins.
I am planning to change colour from navy blue to white on my Cinder 22 topsides. Since the previous paint was not 2-pot (softened by No.9 thinners) I have removed all traces back to the gellcoat with a random orbit sander initially with 120 grit, followed by 240. For anyone considering doing this it is not as tough as you might think, I think the secret is a powerful sander, mine is 420W (£25 from B&Q), and regular changes of abrasive sheets (I got through about 30). I managed to get all the paint off in 4 x 3 hour sessions. The surface appears to be sound. After a thorough wash down I will move into an artificially lit shed for the painting. Temperatures are unlikely to be much above 10 degrees until March by which time I want to be on the water. I will set up a bright halogen security type light to provide enough oblique light. I am planning on three coats applied with Jenny roller/Jenny brush 1st of undercoat, 2nd of undercoat/topcoat 50/50 and 3rd of top coat.
Questions: Do I need a final rubdown with fine wet/dry? The surface after 240 grit seems very good with no obvious scratches. Will 3 coats be enough to fully obliterate the navy gellcoat? Is one of top coat enought to get a good gloss? Any advise on the Jennyroller/brush technique?
