PhillM
Beta 14, new last year, 50 hours on the clock:
Last weekend we ran our engine for about 30 seconds with the seacock blocked. Realized quickly, stopped it, cleared the blockage and carried on.
The engine smelt a little hot and I saw steam coming out of the engine bay. Not much, just a bit of vapor.
The engine overheat light did not come on but I think that the coolant got hot, expanded and blew out of the cap / overflow tube onto hot engine parts.
My plan is to need to check / replace the impeller, top up the coolant and run under load for 15 minutes, leave to go cold and then check the coolant again - all as per the manual.
Is there anything else I should do?
I ask because today when I was buying coolant at the local marine engineers, they suggested that there could now be air bubbles in the system and I might need to drain the system and refill.
