pandos
Some how or other the old halyard (steel) which I have used as a topping lift and the main halyard are now on the same sheave at the top of the mast, in order to raise or lower the Main the steel halyard needs to be released and manipulated every few feet.
Short of going up there does anyone have any suggestions on how to cure..
Mooring Question.
Mooring consists: short line with eye on both ends passing through buoy, boat tied to top eye, swivel attached to riser just under the water, riser which equated to water depth at high tide, shackled to 10 feet of ship's anchor chain ( 35mm) anchor chain shackled to 40mm loop of steel protruding from 2ton concrete block burried in mud for 12 years.
mooring has not been used (by me) for five years. Previous to that it had been replaced about 2 years earlier. Yesterday I took about 20 stone of mussels off the shackles and swivel to discover that they were completely unworn and looked as good as new, ditto for the shackle at the end of the riser connecting to the ships anchor chain.
Is that it,? do I need to do anything else, all shackles are moused with two each nylon tie wraps and all are intact.
The riser is green polly something and have been told this lasts about 20 years, longer if it is protected from sunlight..... rational thoughts appreciated....
( there is a possibility that it was all replaced about two years ago when a boat dragged and wrapped its self up in my setup but I have no way to check this out, but would explain the current state of "non wear ")
Regards
Mooring Question.
Regards
