lpdsn
Looks like I'm going to have to replace or at least re-bed the portlights in the hull over the winter.
They're held in by screws and sikaflex. Cutting the sikaflex from outside looks like it'll be easy with an ordinary Stanley knife or similar.
To cut the sikaflex on the inside I need the blade to move parallel to the window, which is going to be pretty impossible to achieve with a knife. I've an idea of the sort of tool I want, with the blade at 90 degress on the end of a flat piece, so I can run it around the surrounds whilst it cuts the sikaflex.
I've tried to sketch it up very quickly in the attached PDF. The trapezoid on the end is the sharp bit, but there's no special reason why it has to be exactly that shape, it's being able to cut a 90 deg as it is moved from side to side that is important.
I've never seen anything like this. Any ideas?
