Zneg4
New Member
Hi all.
Wondering if anyone has had a similar experience to mine.
I used my Tohatsu 9.8 2 stroke recently and after running fine for 15 minutes at 3/4 throttle, the revs started to drop, and I noticed it had begun to overheat. I let it tick over to cool down, then stopped the engine. Upon lifting the leg, I found the wash plug had fallen out.
I guess this meant the cooling water was partially by-passing the cooling system.
I managed to limp home on tick over with cooling water coming out of telltale.
When I flushed the engine (as I always do after use in saltwater) I found the engine starts easily but when revved, it ' hunts' ie it revs, dies then revs etc.
I have fitted new plugs.
Also checked fuel line for air leaks but no different.
It sounds like fuel starvation, but I am worried that the short overheat has affected the crankcase compression. Before I start stripping carbs and further, has anyone any advice?
Many thanks
Many thanks
