ex-Gladys
Recently "tried" the above job by the handbook, which says "remove drain plug, then remove level plug"..."refill through drain plug unitl it comes out level plug, insert level plug, insert drain plug"
Finished up with SAE90 all over the place, and hopefully enough in the gearbox. Does anybody have a method to do this that works, as SAE90 oil container tubes are too big for the drain plug hole, using the level plug means the oil comes straight out agian.....
<hr width=100% size=1>Larry Botheras
Anderson 26 "Amber"
Anderson 26 "Amber"
