ip485
I go that way often, albeit in a slightly larger yacht.
Portsmouth to Weymouth should be a sensible and relatively easy passage in the first hop. There are alternatives of course. Yarmouth to Weymouth shortens the jounrey and they always look after you very well. Portsmouth to Poole also works, but personally I am never that keen on Poole. Weymouth is an easy harbour in most conditions and should be no problem entering after dark if you need to. In some ways just for a night stop Portland is better. It saves the slog out of Weymouth and around Portland by quite bit, Portland is nice enough, if a little soleless. Make sure you go through the right entrance!
The Race off the head usually provokes commnent. I always favour the inner passage, which means get really close to the shore all the way around. It shelves really steeply and a few hundred feet away you will be fine. Anything less the a F6 is fine. Going around the overfalls is a long way!
Lyme Bay is a slog. Dartmouth or Brixham are your best bets. Brisham is perhaps surprisingly lovely, but expensive. Dartmouth is equally beautiful and a lot less expensive and with lots of options from anchoring, to a cosy berth for the night.
Both are fine for after dark arrivals, whereas Salcombe is more challenging at night if you are not happy with night arrivals. Salcombe is also of course amazing, if just that much further. I always think see how you go across the Bay, and then make a decision whether to push on to Salcombe, or nip into Brixham or Dartmouth.
Salcombe to Fowey is such a nice trip it is difficult to say no, but Falmouth is the obvious destination, if again a bit of a slog. There is nothing between the Helston and Falmouth, so take your pick.
Newlyn is really your last bolt hole and fine by arrangement. Obvioulsy a very busy commercial fishing harbour, so speak to the harbour master before.
I didnt make the SI last year, got as far as Salcombe. I am a little further East, and for me the trip to Dartmouth or Salcombe is just about doable in a long day in the Summer, and another long day the the SI's, but two hops are a decent passage, and if you are going to sail it in a typical SW'ly you ideally need a good wind. If you get lucky of course an Easterly is the answer, but still good passages.
Sounds wonderful and enjoy.
