21FtFreedom
New Member
Hi guys
I'm quite the newbee when it comes to engines. I'm just figuring this out as I go along, so appreciate everyone's patience and advice.
A couple of years ago, a friend and myself bought this 'project boat' for next to nothing - a 21ft Shetland 640.
Some compression testing showed that we had lost compression on all four cylinders, to varying degrees.
Two years - and a global pandemic - later, I've finally stripped her down.
What did I find inside? Black gunk and a sort of carbon residue all over the top of the cylinders / pistons. No wonder we weren't getting any compression!!
I've taken all the pistons out. And now I'm trying to figure out my next step.
Should I have them bored? Can I get away with some kind of home-brewed honing method? Or should I just buy a refurbished block with everything already fixed?
I've attached some photographs of the cylinders. Running my hand down the surface, I'm some what confident that the discolouration you can see is only staining.
Right at the top though, there's definitely a lot of pitting. You can see the black / brown sections. But I wonder how important this is, since the seals on the pistons don't seem to rise this high at any point?
Any advice anyone can give me is much appreciated. Especially if you've had any experience tackling something like this before. Anecdotal advise is always useful.
Or if you have advise on how much I should be paying for re-boring.
Many thanks in advance.
