gunnarsilins
On my Moody 42, built -77, has a yard installed bonded system with all underwater metals, like prop shaft, through-hulls, rudder stock and stern glands interconnected to each other, battery minus and a limpet anode.
As far as I can judge this system has been fine, and during my ownership I have introduced a bowthruster with its own anodes, also bonded into the system without any problems (these thruster anodes are used up to 80 % in a year)
But last year I introduced two additional things.
First a new fridge compressor with keel cooler, with its own anodes. This cooler has a ground lug which I connected into the bonding system, which also is according to what´s written in the installation manual.
I also introduced a shore powered 2 kW water heater for the cabin heating system. The system also has a heat exchanger plumbed into the engine cooling system.
Now things begin to happen. After three months in water the anodes on the keel cooler has been almost entirely eaten up, but all other anodes (bowthruster, propeller and main limpet anode) show only normal wear.
My immediate thoght was that there is something happening with the keel cooler - but what? It cannot be stray currents - they should be shorted out to battery minus.
But suddenly a more scary thought occured - the AC powered water heater has its housing grounded, and this AC ground has a connection (?) through the circulated anti-freeze mixture to the engine plumbed heat exchanger, which in turn has a connection (?) through the engines coolant to the engine block, and further to the sea water?
Is this scenario possible, and thus introducing small voltage differences to another shore powered boats at the marina?
And would a isolating transformer be the best solution?
Thoughts and ideas anyone?
