To antifoul - or not?
frderek
21 Aug 2013
Jersey, CI
Hi,
My Westerly Merlin 28 is on the drying-for repairs to the rope-stripper. I have pressure washed her to remove weed and notice some patches where the antifoul has come away completely but most of it seems OK. She was last antifouled last April so is overdue if I am to continue to use antifoul. HOWEVER I plan to have her lifted out (either over winter on in the spring), slurry-blasted to remove all the old antifoul and then treated with coppercoat copper/epoxy. So the question is do I treat her all over now, treat only the bare patches or not bother at all?
tia for your advice,
Derek
Tranona
10 Nov 2007
3 litres of Basic AF is around £40 plus a morning's work to do the lot. Summer is the worst growth period and the bottom will look like my garden by autumn!
AntarcticPilot
4 May 2007
Cambridge, UK
www.cooperandyau.co.uk
Hi,
Derek
Coppercoat is really all or nothing. Of course, you can treat patches - you always have to, to do under the support pads - but the more you can do in a single session of application, the better as that forms a chemical bond between coats.
frderek
21 Aug 2013
Jersey, CI
Yes, I realise that and being a bilge-keeler there won't be any support-pads(?). The question was, do I need to spend money on conventional a/f now, or just let her fur-up a bit before the autumn lift-out? I may compromise and buy a small tin and do the bare patches :)
sailorman
21 May 2003
Here or thertemp ashore
prime the bare patches with under water primer
