boatone
Is that the 55A one - item 6 on the wiring diagram?
Yes but the block is isolated from DC negative,
The bottom relay in the diagram closes to connect the DC negative to the block during "stop" (and "preheat") It is energised via the diodes in the wiring loom from the respective connections on the key switch
So Scottie is right.
I had assumed that the block would be 12v-ve as has generally been the case on previous engines I have owned...
There is a fuse in the earthing cable, on mine it looks like a white plastic block with two screw terminals.
