Moodyjim
navigation; been looking on the net but there is such variety of clocks and watches it's difficult to decide. What do you use and recommend?
Just confirmed that with a google. Interesting that Stokey Woodall told me the difference was only 1 second (in 2001).GPS system time is about fifteen or sixteen seconds ahead of UTC.
So - use GPS to check the accuracy of your clock but set it using the pips or WWV.
WWV Colorado broadcasts on 2.5, 5, 10, 15 & 20 MHz. You should be able to get it pretty well anywhere.Only if you're on LW and within 400 miles of R4....
Except that you might be using Astro because GPS is unavailable of course....
Your GPS receiver may or may not apply the correction.
Your GPS receiver may or may not apply the correction.I've never seen a (modern) GPS receiver that didn't display ~1 sec accurate UTC.
The point is that you use the gps time signal to check the accuracy of your chronometer and log your lat/long. Then when the gps goes on the blink you have an accurate starting point to continue with the old-fashioned astro.Except that you might be using Astro because GPS is unavailable of course....
you are always going to get delays on any radio broadcast. GPS has built in ephemeris data to calculate the local time from the satellites, so it's only the delay from receipt of data to processing and display that you need to worry about. Even digital radio has a processing time from receipt of signal to output.
I'd use gps over most forms of accurate times displayed unless the chronometer has been set to an accurate non radio signal very recently, and the chronometer keeps good time without external input.
The problem with GPS time is not the propagation delay, it is the lack of leap seconds being added since launch. I'm not sure this is corrected for.
I'm afraid I don't although I know there certainly were some that didn't. I can't remember which one(s) they were, and I accept that they are almost certainly out of production by now, but there could well be some still kicking around.Do you have a list of gps units available to the general public that don't?
