ianc1200
Is it possible/sensible to split a timber mast & glue back together again?
Last winter I bought a Mk1 1978 Cornish Crabber, and the only point on the survey requiring immediate attention was the glued joints in the mast were opening up - this was in several places, with the worst area at the base & about 2-3mm.
I poured thickened epoxy in & quickly realised it was all going down into the void for the wires for mast head lights and the VHF cable. Eventually it was glued to my satisfaction, and after a panic when I thought it was glued too wide to fit into the tabernacle (it was OK) the mast was varnished & put up for the season.
However I then found the VHF aerial wasn't functioning but the mast head lights, despite the cable being very old, was OK.
I now have the mast down, all lights etc off, and there's obvious movement of the cables at the top of the mast, but none at the base.
It has been suggested I have a groove routed in the mast & re cable that way, but I just wonder whether I could go to an expert & ask him to spilt the mast, re-wire & glue up to the original width. As the mast is 35 years old, this would also give me reassurance about it's condition.
I don't even know what sort of "expert" I'm looking for (general shipwright - or a specialist mast/spar company like Collars?).
