Timber Deck
Tranona
10 Nov 2007
Are you leaving it bare like a teak deck? If so, perhaps Douglas Fir is not the best. It was traditionally used for decks on fishing boats because it was cheap and stands up quite well to being constantly soaked in seawater. However, it is not very durable and can suffer from splits and cracking. It weathers to a dull grey unless it is finished with a coating such as a varnish - not really suitable for exposed decks. So, either leave bare and accept it is not long lived, or coat and lose its non-slip qualities.
johnlilley
30 May 2001
South Dorset/moored Poole/lay up Wareham
www.seasurveys.co.uk
Hi there
iroko is used occasionally as a laid deck. It has to be fastened well, as Iroko in small section can twist until it has really settled. The other thing is that any splinters can turn a bit septic, but if cut correctly should not be a problem.
It can be treated the same as teak generally & will weather similarly. It is durable & hard wearing, perhaps more so than teak.
Some specimens of iroko are difficult to cut as they have silica drawn up into the timber as it grows, the very dark brown iroko (it can vary in colour) is quite heavy & the one that is difficult to cut. The pale iroko (or less dark) is easy to cut, has no silica & is lighter in weight.
All iroko darkens considerably on exposure to light/oxygen after 14 days.
It can be almost the same as a teak deck to the unfamiliar eye if well laid. It glues well & the seam filler sticks better to iroko than it does to teak. Less oil.
John Lilley
