Philip Robinson
Sounds very weak when going up
Thanks Fred I'll go get that kit tomorrow and get back with yaProbably needs bleeding and topping up with ATF. Easiest with a threaded fitting to screw into the filller hole with a pipe into a bottle of fluid. Half fill the bottle with ATF and tip it up to let the fluid flow down to the pump. Work the motor up and down. Beware the pressure can build in the bottle and cause some fluid to blow out. A little at a time is best and then release the pressure. Once the air is out it will work again. Fill until ATF is up the the filler hole.
Check no leaks from the ram seals.
You can buy specific kit to srew in with a pipe and plunger arrangement to screw onto a bottle of fluid.
