Seajet
Chrusty,
though my boat has ended up with a fair bit of kit, I've bought it long after years of sailing without, so hopefully won't get complacent...
One thing, I don't know about your boat ( sorry if I missed earlier clues, what is she ? ) but I'm rather keen on the fact she has no skin fittings at all.
The loo is chemical - which is just as well from what I hear of holding tanks becoming mandatory - and I pump out the sink via a Whale bilge pump into the outboard well, where there's a seacock above normal water level, in case an emergency involving change of trim put it underwater.
The pump is the type one inserts a handle into when required, fitted in the bunk side; there's a diverter valve and coiled intake pipe under the sink, so I can pump her out while cowering below ( there's also a pump handy by the tiller ).
So the depthsounders are internally mounted, and i use a trail log on longer trips, putting up with the plotter and knowing the boat to judge speed etc in normal sailing.
As lightning strikes are said to often blow out seacocks, and the Carter 30 I had for a while ( went mad, sold my Anderson, instantly regretted it, had Carter for 3 years then managed to buy my A22 back ) - had 7 seacocks, always at least 1 on the blink despite maintenance, I sleep easier in every way knowing there are no holes in the hull !
The Carter's paddlewheel log was hopeless anyway, always clogging up with weed or wee beasties taking up residence; removing the impeller and capping the fierce jet of water was always good for adrenalin, I couldn't help thinking " One day, I or someone's going to get this cross-threaded ! "
I'm not at all sure trail logs are still available though, or at least affordable ones, my Wasp is fine for cross-Channel stuff...
