thinwater
OP says electric start (only) so presumably needs a battery to get a start. Worth exploring to confirm there is no option for pull start. Often remove the cover and wind a rope around the flywheel. If indeed there is no pull start option then yes you need to ensure you do not flatten the battery at night or from use of auto pilot. I think safest option is still a second battery given that the one battery will die of old age at some time even if he is diligent to not discharge it too much. A jump start pack might be another answer but I would go for a second battery. ol'will
You are correct, he did say "only," but as you say, they always have an emergency pull cord provision. A have twin Yamaha 9.9s and have used that feature once. But yes, it complicates things. I've always thought elelctric-only was a dumb option on small motors. Yamaha added the cord back on some electric start options.
The benefit of solar is that it will be adding power while the helm is drawing, even on cloudy days. I'm not guessing. This is the set up on my F-24. But adding a second battery is smart too. If you are going to cruise, this is not either or, it is both.
Setting up the boat for a balanced helm also reduces the draw.
