Saltram31
Just replaced my cutlass bearing and have re-installed the 2 bladed prop. I cleaned the key and key way to remove any burrs with wet and dry,greased the shaft and fitted the prop. My problem is that when tightening the dome nut ,I can not get the split pin and grub screw holes to line up with the ones in the shaft when fully tightened. I need to turn the nut back about quarter turn to line the holes up. The prop seems fully seated so not sure where the problem lies. Appreciate any help.
