Koeketiene
Strong cleats though
![11896145_723098074501218_7021731665547263530_n.jpg](/proxy.php?image=https%3A%2F%2Fscontent-cdg2-1.xx.fbcdn.net%2Fhphotos-xpf1%2Fv%2Ft1.0-9%2F11896145_723098074501218_7021731665547263530_n.jpg%3Foh%3D8418190bc107101c13b5c5af9e500a68%26oe%3D567475D3&hash=be96a1215c560ed5290e680c66d91919)
Where to Dry Out in Guernsey - need to inspect rock damage
Yes I hit some French granite! Was in an anchorage between Ile Grande and Ile Morvil (north of Trebeurden.) Unmarked ( no buoy or post) and not on my Navionics chart. No water in the bilge - I've got an encapsulated keel. But there is bound to be some damage to the GRP. I told my insurers and headed for Guernsey.
Next I think I need to dry out and inspect the damage. Of course I can use a travel-lift (Boatworks or at St Samson) but I was hoping to avoid the expense. I'm thinking a nice sheltered wall to lean on, or posts like at Warsash. Have you done that in Guernsey? Or have any advice on where's a good place?
We all get it wrong occasionally, after all the published tidal heights are only 'predictions' anyway, aside from cock-ups, if you throw in some particularly high/low air pressure or a strong wind from a constant direction for several days it can easily throw your calculations; that said, to get it as wrong as that photo shows has taken some real effort and commitment. All said smugly from the St John's River Florida, with it's spring tide range of 8".
That doesn't look so much like a tidal miscalculation so much as a boat that has fallen away from the wall while drying. Bad mistake. Worse than failing to attend your lines in a lock going down and having to use a knife to free yourself, which I have seen.
I said it was a bad idea to buy the almanac in Woolworths!
That is very recognizably the drying ramp inside Victoria marina in at Peter Port Guernsey so yes you are 100% correct A halyard taken to a point on the quay wall may have helped lean it the right way on taking the ground.[\QUOTE]
It's also a very long time ago!
When was that picture taken? Not seen a Woolworths for decades!
