Pagetslady
Hi the rudder on my Corsair seems quite stiff to move even with the cables disconnected, I am in the process of fitting new cables and re routing the cables, but I had a thought there are loads of fairly cheap roller thrust bearing that could be used to replace the system used at present which are very basic just the plastic head of the top bearing and the Metal support ring and grease as there is no water in this area i thought a thrust race would reduce friction, has anybody tried this or already has a system that supports the rudder weight by a race.
Mike
Mike
