ruvane
I intend replacing all my old skin fittings and stopcocks, but I'm undecided as to what to fit as replacements. Firstly the choice for skin fitting is between bronze and suitable nylon/glass-filled fittings. If the "plastic" option is not so great, how come so many transducers use such fittings without serious problems?
If using bronze, why should a stopcock directly attached to it not also have to be bronze to prevent corrosion?
If using "plastic", what is the best method for connecting stopcocks as they obviously cannot be screwed directly to the fitting as with metal ones? Do they necessitate a short pipe from skin fitting to stopcock, then on to the pipe again?
What are the relative merits of gate valves/ball valves/etc?
As you can see, I'm looking for all the info I can gather regarding the choice of fittings.
TIA,
Ruvane.
TIA,
Ruvane.
