nigelmercier
RIP
- Joined
- 20 Jun 2007
- Messages
- 16,234
- Location
- Live in Kent, boat in Canary Islands
I recently needed to throw a line over my bottom spreaders, it proved impossible. I have since invested in a cheap slingshot (sometimes wrongly called a catapult) and a number of small rubber balls:
http://www.ebay.co.uk/itm/390615552762
I drilled a 3mm hole in one of the balls, and hollowed out an 8mm diameter cavity with a Dremel. I got a short length of 3mm cord and knotted a loop 25mm from the end, then cut it off close to the knot. I covered the knot in epoxy glue and partly filled the hole in the ball, then pushed the knot into the hole. When it cured, I had a small loop firmly fixed into a rubber ball. Attached to a length of thin twine, this has been surprisingly accurate when fired with the slingshot.
