rjp
I'm posting this to Classic Boat rather than PBO as it's a wooden boat problem and I can do without the inevitable 'castor oil in a plastic tube' answers. After 4 years ' restoration (on and off) I finally got Alysia (Buchanan Scorpion 32) launched at the end of June. Everything went like a dream and despite 6 years (at least) out of the water she was pretty tight within days (with the help of some lard to stem the initial inflow). However sod's law dictated that the depth transducer got damaged at some point, probably at or around survey time when the sole was up. There is obvious damage both to the inner end of tranducer moulding and to the cable insulation and I do not seem to be getting any signal at all. Anyway, what would have been easily replaceable a couple of weeks ago is now a couple of feet underwater and of course it's a through hull fitting. I've managed to obtain a replacement depth transducer of the correct frequency, though I have no way of knowing if it's the same diameter and length as the original until I can get the latter out. I also have no idea how the original is sealed in. My tentative plan is to find a convenient wall to dry out against, cut cable and remove nut from the inside of the existing thing. Then I'm unsure whether to pound it out from the inside (possible planking damage?) or somehow try to draw it out from below (drill a hole up though the middle and devise some kind of a puller?) My next problem will be what to do then if the size is different. Also what should I use to seal the new one in. Bearing in mind that everything has to be done within one tide, does anyone have any ideas or advice to offer.
John
John
