yelbis
Hi
Please does anyone know the manufacturer of the attached photo throttle/gear lever from my 1990 Dehler 34. unfortunately, I can not depress the middle button to disengage from drive. The engine is a cold start and has to be started with lever in full throttle position.
The pin has sheared and it also lookes as though the nylon bush that is on the reverse of the unit has become worn/damaged over time. I can not get the handle off without damaging the plastic facia, the material is alluminium and appears pretty much solid.
Are there replaceable or repairable thanks. The foil label is worn, it reads ?????? Controls
