Tradewinds
On my Profurl the aluminium foil sections are held together with alu joiners held in place with stainless shouldered grub screws The riggers used Duralac rather than threadlocker as advisd in the assembly instructions. A while back I had a couple of grubscrews come loose and the foil section pull apart. Only a couple so not a big problem that time. I can see why they recommend threadlocker. But, when I tried to dismantle the foil to replace the forestay even these Duralac'd small grubscrews were a devil's own job to get out and I was worried about rounding the hex socket off. Heat and persistance coupled with brute force worked - but it was a close shave in a couple of instances.
So my question is, will threadlocker provide some dissimilar metals protection or am I better to stick with Duralac and hope there's enough 'grip' and the grub screws don't work their way out? I don't fancy having to drill these buggers out at some point in the future.
TIA
TIA
