pcatterall
I have been trying to get to grips with thread and fitting sizes related to fuel pipe fittings.
I wonder if others have struggled and if there is a quick clear guide that can be recommended.
I now realise that a lot of fittings are decribed by their pipe size British Standard Pipe ( BSP)
and then these may have the suffix T (taper, where the diameter accross the threads reduces) or P ( parallel where the diameter across the threads remains constant).
I am still not sure about the application for these different sizes.
There also seems to be a fine thread NTPF and there seems to a system where the diameter of the threads is alluded to rather than given.
As an example I had bought a fuel pump and needed a hose tail to fit it. The tail part was easy 8mm (5/16" ) diameter. I can see that the threads are fine so I guess that NTPF is required. The thread diameter required measures at 3/8" but there doesn't appear to be that size anywhere.
Back to my question..... is there a recommended guide to help sort out the sizes and if possible the range of fittings available?
It will be much appreciated!!
