Loctite Blue. is about right as you can undo it OK a couple of months later
Do NOT use loctite red as it is extremely difficult to undo & I have had to use heat to get it undone
If you go on the loctite site it should tell you
There are cheaper alternatives, but a bottle of the stuff lasts so long it is irrelevant over the long term
So the Port is trying to undo itself in Fwds and manoeuvring in the marina the Stb in R .
The zinc obviously shrinks as time goes by .Despite the 243 I find them esp the Port one coming loose after a few months .
Its easy in the Med ( warm ) to tighten them up .I regularly check them after about 4 months .
The bolts are very long .
Just theses .
Don’t use it for static anodes .
