Thread cutting oil
dunedin
3 Feb 2004
Need to cut some threads into the hard alloy masthead. Have shiny new thread taps - but forgot to get the right thread tapping oil
Will any of the on board stuff work - eg WD40 or ProLube or do I need to go hunt some special oil?
Nothing special needed. Thin oil is fine for hand tapping, it does need some lubrication properties, so perhaps WD40 isn't ideal but better than nothing.
I just did a google
http://forums.mtbr.com/tooltime/alternatives-cutting-fluid-288401.html
Unemployed Mechanic says
"For simple hacksaw cutting, any light lubricant is perfectly fine. For non-precision work like that, cutting fluid just extends the life of your hacksaw blade and makes the cutting easier. If the steerer tube is aluminum, then it will be pretty easy without fluid and the blade will just dull a little faster. WD-40 works fine (a good way to use up that extra can lying around the garage, since it has no other use for bicycle repair )
In contrast, a high-grade cutting fluid that is more or less specific to the type of metal your cutting is required for any frame machining job, because the facing and reaming mills are much sharper and leave a very smooth, precision cut. Fluid is needed to dissipate heat that concentrates on the cutting tips of the mill, which would otherwise dull rapidly from the metal work-hardening (typical of most steels) or chip from the galling (aluminum will readily do this). A chipped or dull machining mill can be $100+ down the drain, hacksaw blades are $4-5 a piece.
You dont say what "alloy" but I assume its an aluminum alloy
Paraffin according to my "Intal" drills and taps information booklet
WD40 is said to be mostly white spirit plus a little thin oil so should be fine. Similarly I would think diesel oil
Dunno what your "Prolube" is. It appears to be a brand name encompassing a wide range of oils and greases
AIUI WD40 is largely kerosene which is a recommended cutting fluid for alumium. I've certainly used it in the past with good effect.
Boo2
I have used taps dipped into Vaseline (Petroleum Jelly) which, like grease, prevents the swarf from falling into the void below the tapped hole.
I have no use for WD40. (Don't like the smell).
any thick oil or grease should be fine, it's only aluminium, just remember to make a quarter back turn and break the swarf regularly and you'll be fine.
You don't really WANT whatever you use to be a good lubricant! You want it to help dissipate heat, and lubricate only just enough to prevent galling. As has been said, paraffin is traditionally used for aluminium alloys.
