Says it will ..."cruise all day at 100mph..." but I can't see where all the fuel tankage could possibly be...
The drug smugglers are getting rid as although they can outrun the US Customs boats the Customs guys are now using helis with airborne snipers who can hit the engines on the go fasts.
I can't believe that she came out of Skater with that absurd setup.
Well, in principle it's possible, with a 46' air entrapment catamaran and 1600hp each side.Do you think it'll do 160mph?
Forget trimming in with surface drives, on any 3-digits speedboats.What design elements mitigate against the thing flipping up and doing a Donald Campbell.
Ok presume the drives can trim in ( hence no need for drag inducing flaps ). Any thing else ?
Reason I ask modern Ferraris have ground effect underbody ventures .this means normally up to 80 mph you notice nothing .How ever over say 80 you start to fell it pushing down @130 to 180 there's a big force that you can feel throught the steering pressing it down -sucking it the road ,along with rear suspension designed to give a bit of rear wheel steering -total package is confidence to take curves /bends at high speeds .
How's that boat stay flat @100 -160 mph ?
Mmm... Does it, really? I mean, in any meaningful/measurable way?Helps the boat run better
