C
catalac08
Guest
Issues at home with poor tv signal and I found that the co-ax cable from chimney mounted aerial was badly corroded in the copper stranded shield, the cellophane coated with aluminium was just down to powder and the outer plastic was so brittleit just came apart by pulling at it with the fingers. On reading about co-axial cable I was amazed to read that it only has a life of 5 years outdoors, before corrosion and degradation and loss of signal takes place.
It is not something I had given any thought to previously but I assumed that it lasted pretty indefinitely. I had planned to replace the boat aerial at the masthead over winter (poor reception and even poorer transmission) but it seems to me know that the cable should also be replaced, at 39 yars old I suppose it had done it's time even though only the top few feet is out of the mast.
