vyv_cox
Our UK boat is a 1973 Colvic Northerner, 26 ft. Unfortunately, when she was built all the external timber, quite a lot on a motor boat of that vintage, was all attached by galvanised steel bolts. Many of these are now almost totally corroded away and it is a never-ending task to replace them. We are currently replacing the timber and bolts around the forefoot where there have been significant leaks.
It has been almost a working day's work to remove five bolts, due to access problems, dismantling furniture and bolts heavily rusted in place. However, we finally got there and I set about measuring the hull thickness so I can order new bolts. The minimum thickness of the layup is 1.25 inches, a couple at almost two inches and at one, at the maximum turn of the stem, it is three inches thick! Peering into the hole suggests it is solid all the way, no voids that I can see.
