Porthandbuoy
In a raw water cooled engine is there a risk of antifreeze damaging the exhaust hose, silencer and/or anti-syphon waterlock?
My thoughts too. Rather obvious to anyone that has winterised an engine of this type. My 3GM F takes about 30mins in Scottish October temps.Sorry you got the snarky response. I didn't need any tea leaves to guess why you wanted to know
When you introduce the cold fresh water the thermostat will immediately close.
If you have block drain clocks or plugs then the sea water can be drained using these then replace or close drains and block can be left empty or filled with antifreeze. There should be an air release hole in the thermostat to allow this to be done using the engine. Takes about two minutes on mine though not a Yanmar. This also fills the exhaust trap with antifreeze. This may be important if leaving the boat ashore.h
