Magaz97
On my Invicta 26, I have Two tube heaters, connected to shore power, with a honeywell thermostat in line.
Shore power- Thermostat - Multiplug -Tube heaters
I have power to the thermostat.
The heaters will only switch on if I turn the thermostat down to ZERO. When I do this I hear the thermostat click on. The heaters will then work for about 5 minutes and then stop. No matter what I do with the thermostat control, it will not switch back on. I can not here it click at all, and my heaters remain dormant.
I thought that the heaters would workk if I turned the thermostat UP to a higher temperature!?; and stay on until that temperature was reached. Is is possible that the thermostat is wired to work in reverse, or am I missing something really obvious?
Sorry if this is all a little vague, but so is my knowledge!
