zxc123
There\'s a hole in my sump pan
Just discovered a nasty problem with the Volvo MD2030 engine in the 3 year old boat I recently bought. The engine has what appears to be a rust hole in the bottom of the sump pan. Result: no oil in engine. Fixing this is going to involve having the engine out, a painfully expensive exercise and right in the middle of the sailing season.
I bought the boat just a few weeks ago. The engine has been run for at most a couple of hours since then (a 5 mile delivery trip) before the problem manifested itself.
Is it worth chasing the surveyors? (I had a full survey, but the boat was out of the water so the engine wasn't run).
Anyone else come across similar problems with this engine type? Any suggestions as to a likely cause? The most plausible I've come across yet is that the boat might have sat with a few inches of seawater above the floorboards for long enough to have an effect on the engine. Not much evidence of this elsewhere in the boat, but it's certainly possible.
