stranded
Can I join back in now!
OK, so I am on the boat. The wiring at the back of the ammeter looks very like that in pvb's diagram.There seems to be a power supply for the light, which also runs onto the voltmeter. The lights work. I am unable to measure any voltage at the sensor terminals on the ammeter, having progressively turned my multimeter down to its lowest setting. so hopefully that settles that I have bugger end it. Minor issue.
I have also found a connection which I think must mean that the boat has the undesirable 'common ground'. It has 6 large blue cables attached to a post bolted onto a wooden bulkhead between the service and engine banks. They are held on by a big nut that was very loose, almost falling off, which I have tightened up. Two are definitely the negatives from the service and engine batteries. The third is presumably from the bow thruster battery. It is not clear where the other three go.
It sounds like there is a chance at least that one or other or both of tightening the nut on the ?common ground point, and taking the broken shunt out of the system, might have resolved the issue, but is there a way of testing that without risking connecting the Ctek charger into the system?
