The OpenPilot project
st599
9 Jan 2006
Some forumites have set up a group looking at the possibility of creating a free open source autopilot system for a yacht. http://www.ybw.com/forums/group.php?groupid=14
Currently we've got a few people working on it, but we'd like more. if you fancy having a crack at code writing or testing - then have a look at the project website : http://pcinst.imolesworth.info/tiki-index.php
Other people are busy looking at NMEA Interfaces, hardware autopilot controls, logging etc. I'm busy playing with control software for forcing boats to stay on heading etc.
Could I ask a favour, I've just released some algorithm test software (with a nice User Interface) Could people download and test it? Will only take 5 mins. Any bugs or system incompatibilities you find can be reported using our online form at: https://sourceforge.net/tracker/?func=add&group_id=271182&atid=1153190 (please pick Bugs from the Tracker dropdown menu)
We'd also love to hear feature requests using the same form (please pick Feature Request from the Tracker dropdown menu)
OpenPilot Controller Test Software - version 1 release
This version tests the PID Controller against a basic yacht model:
1. turning parameters provided by users.
2. wind which will blow the ships heading +/- 1 degree.
3. simple UI - use the slider at the bottom to fix required heading.
Download version 1 from: https://sourceforge.net/projects/ybwopenpilot/
You will need the Sun Java Runtime Environment installed, but most PCs do - if not goto http://www.java.com/en/download/manual.jsp
Unzip the zipfile into a direcory and double click on the .jar file.
Please test and report bugs (e.g. crashes, boat turning 355 degrees to port instead of 5 to starboard etc.) at: https://sourceforge.net/tracker/?fun...2&atid=1153190
All code is available in the Subversion repository
Version 2 - will be released late Aug/early Sept and will include all the bug fixes suggested by version 1 users.
Version 3 - late Sept - will include enhancements to the yacht model (and required changes to the Controller)
Version 2 release
Version 2
Bugfixes:
* Ensured that controller forces turn in correct direction
* Ensured that the time between samples used in mathematics is actual time, not expected time
* Got program to output GPL statement as per chosen licence
Version 3 will be available next month this will have:
* Full API to allow others to easily use the code
* Better control interface
* More Bugfixes as and when they get reported.
Trying to get openpilot work
Hi all. this is my first post, sorry for opening an old thread, but this is the one I need.
I am making an autopilot to drive a RC, boat. And is copy/pasting code from the web, to try make it work. :D
I have completed decyper NMEA messages, and first try to make autopilot I used Cross Track Error. But I'm not satisfied with the result.
Now I am making an atempt to make it run with Requested / Current handling, and I need a PIDloop to take kare of the input, output. I stumbled over ybwOpenPilot at surceforge, but the main site http://pcinst.imolesworth.info/tiki-index.php is down. Are the anyone out there ta'll able to help me?:confused:
I have tried to use the example code supplied, and use it for my advantage, but unsuccessful.
I now My wished bearing in degrees, and vessel bearing in degrees, but I am unable to get it into the program.
Thanks in advance..;)
Greetings from Norway
