lw395
As Flaming himself has said, +/- 3kts of tide can have quite an effect on the effective wind speed
It has quite an effect on the ground wind too, albeit with something of a lag.
This is only correct in sailing parlance. In the rest of the world True wind is wind over the ground. There are rather large industries that rely on true wind for planning. It's what meteorological agencies spend billions predicting.
Sadly the small manufacturers of niche sailing instruments chose to make their own stuff up hence the confusion.
I've never heard a forecaster talk about "true wind". The met office and all those large industries are firmly fixed to the ground so the concept of apparent wind is irrelevant. They just use "wind speed".
The big industry where apparent wind does matter of course is aviation. But they use the terms "windspeed" and "airspeed".
"True wind" is a sailing term - always has been.
see: https://www.metoffice.gov.uk/binari...ts/factsheet_11_weather_charts.compressed.pdf for more details about weather.
I think it's only marine instrument users who delude themselves true wind is worth measuring to closer than 5 degrees or a compass point?
Isn't that because it's only boats (and sailing boats at that) that travel sufficiently slowly for a small difference in wind angle to make any difference to their apparent wind and thus to their navigation? If you're flying, a difference of a few degrees in the true (sailing/ water) wind angle makes virtually no difference to the apparent wind you feel, because the vector of your speed-induced wind is relatively so long. So it's not relevant to your navigation. But when you're sailing at just a few knots through the water, a difference of a few degrees in the bearing of the wind over the same water materially changes the angle of the apparent/ relative wind on the boat, and so affects its ability to point where it wants to go, or changes the forward force its sails can generate from that wind.
Hmm. 56 pages from the Met Office and no reference to the phrase "True Wind".
It describes the correct use of the term true wind. If sailors want to describe the wind/water vector they need to use a different term. Sailing wind seams appropriate to me.The analogy with flying just doesn't work, because there are only three frames of reference, the plane, the air at whatever level one is in, and the ground. When sailing, there are four, the boat, the air, the water, and the ground.
"Wind (ddff)
The surface wind direction is indicated on the station circle by an arrow ying with the wind, the point touching the circle. Direction (dd) is measured in degrees from true North. "
I maintain that it is a widely used sailing term - see any textbook or RYA course syllabus.
I can't see any great value in saying what is the true meaning of 'true wind'.
It just pays to be aware that other people might use terms differently.
If you need to avoid any ambiguity, use another term.
Exactly. The only people that are going to be thinking hard about what the true wind is and how it is being affected by the tide are tacticians on racers and they'll already know what they mean.
But the Met Office don't use the term "True Wind". So I don't accept your claim for it's meaning in "The rest of the world".
The recent Bramblemet thread, where nobody showed any knowledge of the distinction whatsoever, suggests they may not!
