DenningLJ
Just to double check that I've not made a horrible mistake, the falling tide is the tide to ride, right?
Yes if you want to go from Cuxton to Hoo BUT unless you have wheels you will have to wait for the tide to come back in again to get you boat into Hoo.
It dries out completely for several hours either side of high water.
Do you know how much water your boat needs to float ?
On very low spring tides there is very little water in the central arch of the bridge.
Arch on Strood side is best if you are in doubt.
http://www.visitmyharbour.com/harbours/north-kent-swale-medway/medway-inland/
WorkingWhat you up to tomorrow?
Working![]()
You do not want to be going into Hoo on a falling ride.So... Is it worth setting off before the high tide and fighting my way up to get under the Rochester bridge before high tide and then it will slack off as the tide turns?
Yeah, that sounds like it could be a bit of a plan. My boat floats in about four-ish foot of water and low tide is showing for 8:40. If I set off at about 7:30, fighting against the current could take a little bit longer so to Rochester at roughly low tide, under the bridge and learn to tac... the missus will be over the moon but it might have to be a plan.
Are you familiar with the withies - the channel into Hoo?So... Is it worth setting off before the high tide and fighting my way up to get under the Rochester bridge before high tide and then it will slack off as the tide turns?
People, this is why you shouldn't learn everything you know about sailing from Three Men and a Boat.
I've had the seagull running for 10 minutes today and I've got another 5 litres of petrol
Keep to the right.....
Denninglj,
no-one seems to have added the useful bit of advice, sorry if you are experienced but...
on approaching the new mooring, have a look at boats around - afloat not aground ! - whichever way they are pointing, take the same approach line to the mooring; tide is much more powerful than wind unless it's a gale.
Despite all the gleefull doubters on here, it should be a simple fun trip; but do have an anchor on a long line - say 30 metres of at least 12mm nylon if buying it - as Plan B for a pondering period in case the engine packs up, happens to everyone at some point.
Have Fun !
Some Hoo moorings are on trots....
