Tomahawk
On the basis of conversations with friends in the MCA, whom I’m certainly not going to name, what seems to have happened here is that the failure of the prosecution in the Cheeki Rafiki case and the criticism of the MCA in that case caused huge embarrassment to the MCA and their new hyper active CEO, recruited from a housing association, fresh from Grenfell Tower, has directed that no stone be left in-turned to make sure that the MCA is never as embarrassed again.
In which case the resolution is simples.
To not allow a coded vessel to be operated as a private one.
To require that if a coded vessel is removed from the register, the removal process includes a decommissioning report to be passed to the insurers.
If a coded vessel is removed rom the register, it has to go through the full registration survey process again before it can be used as a commercial vessel.
