The Bottom End of The VHF Market..
monkfish24
24 Apr 2003
Cornwall
For sometime i've been thinking about getting a cheap,basic handheld VHF for a while now. I've started doing a fair bit of singlehanding now and would also like one that i can leave in a grab bag. We have a Nasa Fixed DSC in the cabin which is a very good bit of kit but the lead is too short to have in the cockpit so requires me to have my head down the companionway, far away from the tiller, when transmitting or recieveing. We don't have a repeater speaker in the cockpit either so having the handheld would act as a second speaker as long as it wasn't a DSC call.
Wandering around the boat show, i noticed the Cobra 125.
http://shop.sailnet.com/product_info.php/products_id/45316
Priced at £49.95 it suited the budget. I wasn't keen on spending £150 on the Icom that i would probably use no more than once or twice a season. Although they are proven to be highly durable and reliable i just couldn't really justify it. Having worked in a chandlery when i was a bit younger, I've always thought "yee gets what yee pays for" but with Cobra i know they are quite reliable and fairly decent bit's of kit.
Included with the radio is a cigarette power adaptor, 5 rechargeable NiMH AAA batteries, a wrist strap and a belt clip. The clip itself i think is quite an intuitive design, where it is not permanent but can be removed by turning the radio 180 degrees where a latch unclips it from the belt clip.
The radio itself is waterproof to JIS4 standard. Typical 1m for 30 minutes, which is way overspecced for a fair weather sailor :D
The Radio itself is easy to use, it has a dedicated channel 16 button and all buttons are big and easy to press, which i'd expect, would make things easy with cold numb hands. It also has a key lock button which is perfect for jamming in my coat pocket. It transmits on 1 watt or 3 watts. Nothing spectacular but definitly more than enough for my coastal cruising. The unit is very light, probably no more than 400g with the batteries fitted but, this doesn't make the unit feel flimsy at all. The On/Volume button makes a very convincing click and the buttons need a comfortable amount of pressure to be used. I've used radios before where they require too light pressure and end up transmitting short bursts when knocked around.
I haven't transmitted on it yet but recieving is very clear, having sat there in a cafe outside the Excel listening to the safety boat drivers VHF transmissions.
I hope this short review helps you if you were not sure about such a cheap radio but it seems to fit our requirements very well and i am in no way dissapointed with it.
James
We have a pair of these little beasts & for the money they are superb. Basic & simple. What more could you want.
cheap handheld - raymarine
I have got a Raymarine handheld
thats the only one I have
seems to work wonderfully well
not sure that there are too many situations where you really need that long power hugging aerial going right up the mast
but what do I know?
Dylan
Check which channels it receives..
Does the cheap Cobra work on the club and marina channels (37 or M1/M2). When I was buying the small cheap one did not, but I got the bigger Cobra at £89 that did, also higher power, Now 3 years old, works well.
No, stops between 28 and 60, neither does it have M1 or M2.
Thats not very encouraging is it, even though a sample of one is not the fairest sample. All the same its enough to put people well and truly off given their reluctance to replace it. I'd have been off to trading standards like a shot if an allegedly IXP7 rated device croaked at the first splash as it were.
I'm not sure any IXP7 radio would be suitable for kayaking without being inside a poly bag as well, but it should have done better than that for sure.
Tim
I'm sure the cheaper ones are fine - most consumer electronics are pretty reliable these days. Especially the basic stuff that doesn't get recalled for software faults.
If single handed or doing a lot of night sailing on a large boat I'd be tempted to splash out (ha!) on a waterproof handheld and keep it about my person.
These are euro specced for £70, but i've no idea how good they are.
The Midland Pacific Hand held
http://www.burdengroup.com/rcatalog/AppServerProductNew.asp?tab=1&p_code=284434
Tim
I have one, great radio except it is the least intuitive gizmo I have ever owned. Despite using quite often I can never remember how you change channels, drives me mad. Apart from that it's ergonomic, powerful, good for a grab bag because it takes AA batteries and I like the rotary controls.
Another vote for the Midland Pacific,in you price range. Mine`s stood up to astonishing abuse for 2 years Jerry
PS if you don`t care about having it bust/drowned/nicked it will be safer and more useful being in your oilies/tender all the time,not hidden below!
It takes 16 times the amount of power to double the distance of an EM transmission, to me the difference in range of 3 watts to 5 watts isn't a matter when at 5 watts, handheld to handheld, range is about 3 miles.... roughly :)
We too have a cheap-ish hand-held that we use as a cockpit VHF (standard horizon).
Can't help wondering at the logic that says grab bag (ie the one time you really need something to work first time and well) - buy the cheapest kit going!
At the risk of diverting the subject, what are the rules for the use of 37 M1/M2 (and I mean rules, not guidelines/local practice). Its quite hard to work out what they are based on a web trawl as all sorts of different information comes up.
Martin
"Channel M (157.850MHz) and M2 (161.425MHz)
Channels M and M2 are UK channels and should only be used in UK territorial waters. Their on-board use is covered by a Ship Radio Licence. However, equipment that is only capable of operating on these frequencies is usually licensed under a Coastal Station Radio Licence and it is not necessary for the operator to hold an operator's certificate."
From http://www.ofcom.org.uk/static/archive/ra/publication/ra_info/ra264/ra264.htm
