monkfish24
For sometime i've been thinking about getting a cheap,basic handheld VHF for a while now. I've started doing a fair bit of singlehanding now and would also like one that i can leave in a grab bag. We have a Nasa Fixed DSC in the cabin which is a very good bit of kit but the lead is too short to have in the cockpit so requires me to have my head down the companionway, far away from the tiller, when transmitting or recieveing. We don't have a repeater speaker in the cockpit either so having the handheld would act as a second speaker as long as it wasn't a DSC call.
Wandering around the boat show, i noticed the Cobra 125.
http://shop.sailnet.com/product_info.php/products_id/45316
Priced at £49.95 it suited the budget. I wasn't keen on spending £150 on the Icom that i would probably use no more than once or twice a season. Although they are proven to be highly durable and reliable i just couldn't really justify it. Having worked in a chandlery when i was a bit younger, I've always thought "yee gets what yee pays for" but with Cobra i know they are quite reliable and fairly decent bit's of kit.
Included with the radio is a cigarette power adaptor, 5 rechargeable NiMH AAA batteries, a wrist strap and a belt clip. The clip itself i think is quite an intuitive design, where it is not permanent but can be removed by turning the radio 180 degrees where a latch unclips it from the belt clip.
The radio itself is waterproof to JIS4 standard. Typical 1m for 30 minutes, which is way overspecced for a fair weather sailor
The Radio itself is easy to use, it has a dedicated channel 16 button and all buttons are big and easy to press, which i'd expect, would make things easy with cold numb hands. It also has a key lock button which is perfect for jamming in my coat pocket. It transmits on 1 watt or 3 watts. Nothing spectacular but definitly more than enough for my coastal cruising. The unit is very light, probably no more than 400g with the batteries fitted but, this doesn't make the unit feel flimsy at all. The On/Volume button makes a very convincing click and the buttons need a comfortable amount of pressure to be used. I've used radios before where they require too light pressure and end up transmitting short bursts when knocked around.
I haven't transmitted on it yet but recieving is very clear, having sat there in a cafe outside the Excel listening to the safety boat drivers VHF transmissions.
I hope this short review helps you if you were not sure about such a cheap radio but it seems to fit our requirements very well and i am in no way dissapointed with it.
James
James
