The Best Deck?
I just decided not to buy a secondhand boat because of problems with the teak deck. It needed redoing, and there was a chance that water had got into the balsa sandwich, which would have been a costly affair.
The boat I chose has a deck painted with glass-ball non-slip paint, and my old boat had Treadmaster, which I like.
But what is the best deck? Teak has its problems, moulded "non-slip" gelcoat patterns are not that good at all - what to choose?
Lost in Denmark - a yachtsmans paradise!
vyv_cox
France, sailing Aegean Sea.
coxeng.co.uk
Two relatively recent products, Tek-Dek and Marinedeck 2000, receive favourable write-ups. Tek-Dek was covered here quite extensively in the past month, postings include the site of the man laying decks at the time, with many photos and tips. Unfortunately I didn't bookmark it, but you will find it in the archives.
I have had Marinedeck 2000 on my cockpit seats for the past four years or so, no maintenance at all, robust, warm to sit on and non-slip. It is cork strips that look something like teak.
Laying tek-dek looks easier as the product is in its finished state when laid. Marinedeck needs to be sanded, sealed and coated before use.
AndrewB
7 Jun 2001
Dover/Corfu
Deck Paint.
Agree with you about teak 'decking' laid on GRP - it's just a liability, designed to shorten the yacht's life if screwed into composite. It is not really even that good a non-slip surface, though better than moulded GRP.
I've gone for deck paint. It's cheap, easy to apply, and gives an extremely effective grip in all conditions, even icing. I painted it over an epoxy undercoat. First time I tried conventional paint with a little fine sand added. This was effective but the sand didn't go on evenly and looked a bit streaky. Then I switched to 'proper' deckpaint (International) which is slightly more expensive but looks much nicer.
It has a slightly rough feel but is not uncomfortable to sit on. It is a bit soft and wears away rather easily, so can need touching up. I've used patches of Trackmark on heavy wear areas such as where the anchor runs.
gunnarsilins
Stockholm/Sweden
www.eilean.se
I agree with all...
...postings.
Paint: looks good, simple and cheap
Tek-Dek, Marinedeck 2000: if looks are more important and you can allow the cost, they are not exactly cheap.
Treadmaster: best nonslip, but rough on you knees. Looks? Well can be argued....
Real teak: Looks good, when well-kept (rarely seen) but a time bomb of problems.
I have Treadmaster on mine, very worn, but I´ll go for again.
Thanks a lot for confirming my suspicions.
But, as luck would have it, the "love at first sight" boat that I really wanted all along came on the market at the last minute (he'd advertised it, then backed out when I asked him), and could he (the local boatbuilder's apprentice) please take my present boat in part exchange? Could he ever! It's a Laurin 32 (you know the type, Gunnarsilins?), built like the proverbial brickie's khazi, and very nice too...
The deck is new, moulded GRP, though, and could double as a warm-weather ice rink when wet.
Any tips about how to get Treadmaster to stick to it? The chandler will let me have some of his old stock at a good price. It will need to be filled or sanded, right?
Its best to use treadmasters own glue. Also don't just key the surface but heavily score the deck as this increaces surface area of adhesion
vyv_cox
coxeng.co.uk
Agree
Don't think of using anything other than the correct stuff. It's not cheap, but cheaper than getting the whole lot off and laying it again. A previous boat had the whole deck in Treadmaster, stuck down with impact adhesive, I had to get the whole lot off, a massive job that took most of a winter.
I didn't score the deck when laying mine, just dewaxed and light sanded. It has been down for about ten years now, still in good condition and no lifting edges.
