Watergeus
Jubilee River
With the river once again at very high levels, does anyone understand how the EA operate the Jubilee River?
At present, with the level below many locks nearly a metre above normal levels, the level in the Jubilee River is recorded as 0.88m _below_ the normal level. Any idea what's the purpose of this?
You can see the recent history at http://www.environment-agency.gov.uk/homeandleisure/floods/riverlevels/136496.aspx?stationId=7164
I had a look recently at the inlet and outlet of this waterway: the inlet had one gate out of three letting through water; the outlet is a set of fixed height V-weirs, which obviously doesn't permit much control. The recorded height has big dips at about 24 hour intervals, which suggests that the gates can only operate in a fully closed or fully open position.
Now clearly as well as avoiding floods in the Windsor area (it wouldn't do, would it) the EA also has to be careful of not flooding the reaches from Old Windsor downwards and these are already up to flood levels. So it seems that in these conditions the river has very little function.
So what good does it do?
