Heckler
In practice I have also found my digital voltmeter shows a "swing" on the screen when connected to nmea so that you can see if it is outputting. If you are really clever and connect the signal to a 9 pin serial port plug and plug it in to your computer serial port it will show up in TelnetIn practice, an analogue multimeter on an NMEA signal tends to show a fairly distinctive swinging pattern. You're right that we wouldn't be able to see the transitions between individual bits at 4800 of them per second, so I assume this is the gaps between sentences.
Stu
