webcraft
I need to test the steaming light and tricolour on Avy-J's mast. I have a 12 volt battery (the new engine start battery, fresh from Halfords and still to be fitted)
The lights are connected with a single 3-core cable at the moment with a three pin deck plug at the bottom. I am assuming that if I apply 12 volts across the common earth and one of the positives one of the lights should come on, and that the other light will come on when I swap a lead from one postive terminal to the other. But I have a few queries, never having done this before:
a) Am I correct in my assumptions?
b) How can I test which is the common earth and which are the two positives? Continuity test with multimeter?
c) Any particular size of wire needed from battery terminals to deck plug terminals ? I assume any lighting-size cable will be sufficient?
- W
- W
