Billows
Any nice hack to check if bilge water is seawater or rainwater other than tasting (yuk and often inconclusive).
Man up! Finger!Any nice hack to check if bilge water is seawater or rainwater other than tasting (yuk and often inconclusive).
I'm guessing that a hydrometer would work. but I don't know how sensitive and can't remember how to do the calculations. I'll try my battery hydrometer - suck in some sea water to see what 100% local sea water reads, then test the bilge water.
Thanks for link, have bought one if it turns up and works it will have lots of uses apart from its original usage.I did think about buying one of these. https://www.banggood.com/0-28-Prece...er-Salinity-Meter-p-1144661.html?rmmds=search
Amazing what you can get for a few quid nowadays on AmazonI did think about buying one of these. https://www.banggood.com/0-28-Prece...er-Salinity-Meter-p-1144661.html?rmmds=search
The problem is a bilge is likely to have had sea water in it at some time unless it's a sparkly clean AWB so any test is likely to indicate some presence of sea water.
An SG test would indicate the degree of salinity (assuming there weren't more exotic solutes present, which is improbable). This can be compared with the stuff you're floating on.
And if it's a mixture?
A mixture of what? If you're thinking of significant quantities of a solute in addition to those in seawater, perhaps you could suggest what it might be. Barring something like a major kitchen accident (which I think even the most cack-handed cook might notice) I'm struggling to imagine a credible compound.
Possibly one of these? http://www.ebay.co.uk/itm/Rugged-Hy...064369&hash=item51d599869c:g:V5AAAOSwdGFYwhKr
Test some seawater and note the reading. Test the bilge water and you should be able to estimate the seawater/freshwater mix. On my boat everytime I remove the log some seawater gets in resulting in salt crystals once any I fail to mop up have evaporated, so before measuring any future water leakage I think I may have to wash the bilge with fresh and pump everything out to avoid false readings.
