Temperature Sensor Volvo Penta MD2020
mnrkks
5 May 2022
Hello All,
I have a question and hope you can help me, I am trying to understand where the temperature sensor in my Volvo Penta MD2020. I am asking the sensor which creates the alarm, because I guess it is not working properly. I have checked the volvo parts web but there it is not clear where to look. Can you please show me by fotos or any web links that can be useful?
Thanks in advance!
Onur
Thank you peteK I will check it!
Confirm you have found the correct sensor from the wiring colour. White/brown ( or white /brown and black for a two wire sensor on an engine with an isolated electrical system)
If you want to test it the contacts should close at 95C
I thought it was either on the side of the heat exchanger or the side of the engine just under the HE. one being the alarm sensor and the other for a temperature gauge if fitted.
I have
Confirm you have found the correct sensor from the wiring colour. White/brown ( or white brown and black for a two wire sensor on an engine with an isolated electrical system)
I have just fitted a temperature gauge which is on the side of the heat exchanger. I have also changed thermostat and exhaust elbow, so I will be able to check the temperature now if alarm sensor works properly or not...
Hello, I would like to add a temperature sensor for an analog temperature display to my VP MD 2020. I now know that this is installed on the side of the heat exchanger. But which thread do I need??? 3/8 - 18 NPT???? Can someone give me information about this? Greetings André / SY Malu / Germany
Hello Malu, it should be that I can measure mine and can tell you or you already solved it?
Hello, no, I haven't been able to solve the problem yet, I'm still looking for the right size. I just can't find it.Greetings Andre
