Laundryman
3 or 4 mins at full revs and my Volvo 2020b overheat alarm sounds. No problem at normal cruising revs. I throttle back and generally the alarm dissappears. Although I treat the alarm with respect, I'm not sure that the engine is actually. overheating! No smell, no steam from the exhaust etc. I plan to flush the raw water side with Fernox and use an automotive rad flush on the circulating coolant. I have an electric automotive temperature gauge. Can I simply connect to the alarm sensor on top of the water pump and get a reasonably accurate reading? What would be a normal running temperature, 85 degrees? Thanks. Alan
