teleflex with NFB or ultraflex
simonfraser
13 Mar 2004
Outboards 4 mobo’s, unless you do a lot of miles
hm just had the quote for replacing the 20 yr old teleflex with a new bezel and cable vs changing the lot to hydraulic, quite a difference in money
the access is poor, so 'just' pulling the cable out and replacing it is going to be simpler and quicker than rebuilding it for sure
main reason for changing it is the slop in the steering (autopilot is def a minor afterthought)
i am 99% sure it is mainly in the bezel and possibly in the interaction between the bezel and the cable
1) if i have a new bezel kit and cable can i get rid of the slop in that part ?
anyone done this and noticed that it is tight after replacing the old parts ?
2) Teleflex NFB 'contains a clutch that provides the driver with improved comfort and control'
any one care to comment on NFB ?
3) ultraflex seems to have a better bezel system to control the cable, is that correct ?
any one with experience of this vs teleflex ?
Simon, my steering system has a few degrees of looseness CW and CCW before it does anything. I believe the fault is usually wear in the gear unit behind the wheel but you should be able to diagnose this easily. I did once see a 3rd party gear unit that have five cogs instead of three but as my existing unit has lasted 18 years and still works I shall just replace like for like.
I do wonder what you have at present? My KAD44 boat has a VP steering system (STS 330) that I suspect is re-branded a Teleflex unit. You can buy a like for like replacement from VP for £180 or so. Job done!
Simon,
Is Uflex the same as Ultraflex?
Are the Uflex, Teleflex and NFB units the same dimensions?
I'm afraid I have no idea how to fit them as, like everything else, I prefer to pay someone who won't mess it up!
Ha you reading my mind :)
ultraflex control unit, 99% of the play gone
smooth control
more turns of the wheel needed to change course
takes a little getting used to, not the easiest to sort leaving the trailer on a cross tide
and due to the extra turns the outdrive is more stable so the boat does not wander off same moment the wheel is let go of
worth doing to an older system I recon
the mechanic has increased the spec to deal with the KAD 44, according to him the original system was not designed to deal with the horse power
not quite sure how that works as the system is hydraulically assisted anyway ?
Simon. I know we have discussed this before. But I honestly don’t think this is the issue. Just that all planing hulls under like 40ft with a single drive that’s not shaft...will always wander a little left and right. I’d make sure the steering bush is ok on drive, make sure the steering arm linkage is tight and tighten up the cables at each and as you can. I think anyway.
If your steering wheel has a tilt mechanism the UJ gets loose. It's easily tightenned up with a screwdriver but requires the steering wheel to be removed for access.
I've written down the procedure here somewhere before
edit: here Free play in steering.
smooth control
Simon, thanks for the update. I'm glad that the new gear has resolved the issues, I thought it would! By and large, returning tired components to their original condition normally restores functionality without the need for complicated upgrades. Hopefully, you'll be good for the next 20 years now!
As you say, bearing in mind the unit it power assisted, I don't understand the mechanics comments.
I would be interested to know what model of gear unit was fitted to the boat originally and what you have replaced it with.
