oGaryo
So, first snag on the S28 to address. The stbd remote comtrol is hard to get out of neutral and in to reverse, no probs going in to forward. Notably, the swivel bearing shown below seems to be much looser than the port side with holder movng laterally when trying to select reverse. The port side is ok. Once in gear, the throttle operation is smooth on the stbd side.
Has anyone else come across this and tightened up the swivel bearing and if so, how tight should it be please?
To tighten, I presume it's a case of removing the snap on cover, moving the shift cable out of the holder to expose the flat head screw and tightening it.. access space is quite poor though with lots of opportunity to drop something in to the bowels of the helm station never to be found again
